show sflow hardware-utilization
show sflow hardware-utilization {slot [slot_num | all]}
Description
Displays sFlow hardware table utilization statistics.
Syntax Description
hardware-utilization Specifies showing hardware table utilization statistics.
slot Specifies selecting slots.
slot_num Specifies which slots to show statistics for.
all Specifies showing statistics for all slots.
Default
N/A.
Usage Guidelines
This command displays sFlow hardware table utilization statistics for your system.
The following example shows sFlow hardware table utilization statistics.
# show sflow hardware-utilization
sFlow Hardware Table Utilization Statistics
Resource Type           Current    Maximum    % Util.
MAC Entries                   3      73727          0
Host Entries                  4      73728          0
IPv4 Entries                  0      73728          0
IPv6 Entries                  2      36864          0
Long IPv6 Entries             0       2048          0
Total Routes                 11       8192          0
IPv4 Neighbors                5        N/A        N/A
IPv6 Neighbors                0        N/A        N/A
IPv4 routes                   3        N/A        N/A
IPv6 routes                   3        N/A        N/A
ECMP Next Hops                2       1023          0
ACL Ingress Entries          42      10752          0
ACL Ingress Counters          0     233472          0
ACL Ingress Meters            0      12288          0
ACL Ingress Slices            0         12          0
ACL Egress Slices             0          4          0
Legend: N/A - Maximum not defined in published sFlow structure.
              Also see IP usage in 'show iproute reserved-entries statistics'.
This command was first available in ExtremeXOS 22.5.
Ability to select slots in a stack was added in ExtremeXOS 22.6.
Legend explaining N/A entries was added in ExtremeXOS 30.1.
Platform Availability
